J,
I found your Switch Brackets, but no switches. I set up the Optos; maybe use the MicroSwitches at the other end for failure/shutdown. There are a few reasons for this:
- Mech switches aren’t repeatable to fine tolerances because they tend to bounce.
- Optos are highly repeatable, we’ll see if debris from milling fouls them. If so, I’d say go to Hall Effect transistors.
- The “Homing” operation moves into the limit switch, then backs away slowly to repeat the ReferencePoint. This requires precision repeatability.
Unluckily, I found a whole baggy full of Optos on brackets with connectors (scavanged from a copier), about the time I had finished installing the others…I left them in the PCB Mill goody box.
