Just submitted this class for June 23rd. Only has a cost if I supply the wood to you. If you bring your own I suggest not using anything soft like pine or poplar as fitting the lid is more difficult. If you don’t care about keeping it you could use green wood to learn the process.
Class Description:
This class will teach each student the process to create a lidded box on the wood lathe. Students should have some lathe experience. The focus will be on the process and proper fitting of the lid to the base. Students will learn how to use the 4 jaw chuck and how to create and use a jam chuck. Maximum class size is 4 students. Kiln dried material approximately sized to 3"x3"x8" is required. Should be a hardwood for best results. For $8 I will provide you Honduras mahogany.
