If you’re willing to donate the 1/4" sheet - that would be fantastic, that would be extremely generous of you. We can order the square tubing 1"~2" or 2" angle iron for around the edges for stiffness, another piece down the center or two cross pieces for any sag, with 2" legs, a piece length wise down the center, and work out the other details.
We can have a planned work day/weekend so we have enough people to get it onto the plasma cutter to cut it down to 4’ X 6’ and used the drop off for any gussets and leg pads to cut out on the plasma cutter. (it took five to move a 4’ x 8’ 1/8th sheet successfully onto the plasma cam @TBJK Tim had gotten). Maybe even schedule a plasma cam class to cut the gussets, etc. out. Or just go for a 4’ x 8’ table that would allow four stations, an extra for growth. Although maybe a 4’ X 6’ would be a better physical fit.
The frames could already be welded and ready for the top, final assembly in Machine Shop bringing the MIG Welder over. Everybody can have their chance at practicing MIG (anything you aren’t particularly proud of you can grind out and redo. @zmetzing has talked about doing an angular grinder class. This would be a great class for it: Weld prep, using a cut-off wheel, wire brush, flap sanders, etc. to demonstrate and practice grinder techniques, pretty this puppy up. We end up with a great table at the end, several classes learning would be there … great cross over of training for more metal working skills.
Maybe even work in a MIG class from @LeeCJones
Cutting the angle/box iron pieces would be good practice on the Cold Cut saw, do some fancier 45 degree joints. Make it a training day.
We can make this a committee project if that’s the way folks want to go. We just have to plan it out. Could be the Lathe tool post build Tim & Bob @BobKarnaugh have in mind, even the lathe chuck rack, larger pads for larger casters on surface plate.
Be an all day or weekend of learning and build session with a Metal Makers made table at the end for our bench top equipment coming in. What say you all?
