Hello Makers!
This is just a reminder to those making pieces more than a 3/8" thick!!! Winter is approaching, which means pieces are drying very slowly. Pieces may appear dry on the outside but are still wet inside. This leads to explosions in the kiln. The kiln team asks that you ensure your pieces are dried well because this is a community space, and we don’t want pieces going home broken.
- If you are making solid pieces, please make a vent hole for your pieces. Such as sticking a chopstick size stick or ceramic hole puncher into your piece at the bottom to allow airflow into the piece.
- If you are making thick pieces, you can candle them in your own ovens at home. This is putting your piece in the oven at 180/200 degrees Fahrenheit for a couple hours depending on size to wick out moisture in the piece. The process is called candling if you need to research more on this.
- If you are not adhering to these rules and your pieces are being placed on the needs attention shelf, please talk to a kiln team member or the chair to ensure that your method of making is approved. We will not be firing solid pieces during the winter time if we do not feel like it is safe in our kilns.
Lastly, as a reminder, the kiln team asks that people stop putting wet pieces on the greenware ready to fire shelf. It is not fair to our community guidelines and the kiln team members, who have to decide what is safe to fire. Pieces that are wet must be put on the in progress shelf to dry.
Thank you for reading this PSA.
-A
