Good afternoon! My wife and I are new to the space and were working with the vapor hone today. For the most part it did really well, but I kept running into an issue where the rinsing hose and view sprayer stopped working. They usually came around again after a few minutes of sitting, and later we discovered that you could power off the machine, let it drain and sit for a minute then power it back on and you’d get water spray pressure again.
We read the directions on purging, but that didn’t seem to help much. We’ve never used a vapor hone before, and I’m sure it’s just a matter of not knowing something. It felt like it was maybe getting low on water, but I wasn’t sure and didn’t want to cause problems by doing something wrong. (I even tried to look up usage instructions on Vapor Hone’s website, but they don’t seem to publish PDF owner’s manuals there.)
There was a giant water tank next to it that said “For Vapor Hone” but no clear directions on how to use it. It looked like you just plug it in, then flip the switch to pump water out of it, but again, didn’t want to break something from not knowing.
Is there anyone who can provide some guidance on what I’m doing wrong, where to add water and how much? Once we get the right answer, would anyone be terribly offended if I printed out directions on how and where to add water to keep near the machine for others?
Thank you!
