DMS Tribe,
Along the lines of another discussion on spectrophotometry, David Jackson brought up an excellent point about having a satellite electronics mini-lab available in the BioLab area. My thoughts were to add mobility to utility and instead of having a dedicated corner, to instead put it on a moveable cart with a few drawers, shelves and ideally a small tabletop.
In my background as a shop mechanic, you have your main toolbox where you keep everything you own, but have a smaller portable roll-around where the most often used tools are in easy reach for 90% of your tasks.
Given that the electronics room is on the other end of the building from the warehouse, and that it is a pain to go over there to gather soldering irons, solder, DVM, wire, etc. and then reswipe RFID access every time you want to work on a project in another room or because there is a need to troubleshoot/repair a tool like the Bridgeport or to maintenance the laser as Richard Alexander has envisioned, there is a growing consensus to make this happen.
This will also help prevent people forgetting to return any borrowed from the electronics room.
So far I see this as broken down into a few discrete sets of decisions:
What cart works best? (size, material construction and functionality as above)
What should the tool loadout / manifest be for that cart? (and this will grow over time, so there is no need to get everything right in one shot)
Labeling the tools as belonging to the Mobile Repair Cart so time is not wasted hunting them down.
I might point out that smaller parts containers be incorporated to avoid the lumping 45 different things into one drawer to prevent wasting time digging around.
Because this was becoming a separate discussion from the spectrophotometry, it was felt best to break it out into another topic.
Thoughts?
Joel-Anthony āJAGā Gray
