Can’t get it to go back to 90 degrees. Titled to 22.5 and stopped. Won’t move in either direction.
This should be posted in the Issues and Requests category tagging @Team_Woodshop.
Unfortunately, this is a Members Only category for which you need a Green Dot. Since you are a member, you can request one. See:
There is a little black tab on the hinge at the very back of the saw that must be pulled out bad held while not under load. You can then change the bevel position the saw.
The tab is visible at the 50 sec mark in they video.
