At present most cases on thingiverse that do din rail or vesa mounting do not allow for stacking while the original cases we had picked out for the project where discontinued and are now being resold online for six times the original price. So we’re needing someone to create a set of stl files based on the following cases:
https://www.modmypi.com/raspberry-pi/cases-183/raspberry-pi-b-plus2-and-3-cases-1122/hitaltech-pi-b-plus23-din-rail-case-railbox-45mm - https://www.modmypi.com/raspberry-pi/cases-183/raspberry-pi-b-plus2-and-3-cases-1122/hitaltech-pi-b-plus23-din-rail-case-railbox-22.5mm
These should be modified a little to assist with cable management and allow for water cooling channels. If a scan can be performed then we’re able to provide an example case.
We have a short deadline for this project so compensation is comparable.
Please PM me directly or post below of your available.
- Count me in!
- I know someone that can help
- I can make it.
0 voters
