Blueprints schmooprints. There’s no magic sauce. But knowing, for example, what the piston to wall clearance is, as well as the type of pistons used, is critical in informing oil viscosity and makeup. Tight clearances will require lower-viscosity oil with higher shear strength, whereas wider clearances will call for a high-viscosity oil that doesn’t break down readily from blow-by gases. That information will also help determine reasonable oil change intervals.
For example, my CA18DET has measured piston to wall clearances of .005" on an iron block with CP forged pistons. My bottom end assembler (Alamo Autosports) and I have worked out that 5W40 is the most appropriate oil weight for the application, since the clearances are left wide to account for expansion under relatively high boost for this engine application. Conversely, a high-compression NA KA24DE would be much happier with .002" clearances and 5W30 or 5W20 oil. A similar conversation took place regarding the bearing clearances, since my crank needed a decent amount of polishing.
As an aside, I don’t hold that EGT monitoring is critical for most builds. If your engine builder knew your power goals and put it together without EGT provisions, especially if he works with the tuner, he knew what he was doing. I will say, however, an accurate electronic oil pressure gauge is critical, and an oil temperature gauge would not go amiss. Obviously, a boost/vac gauge is important, but make sure the boost portion goes at least 5psi above your planned peak. For datalogging, keep an eye on short term and long term mixture monitors- I imagine you’ve got a wideband O2 sensor.
I also assume you’re running an EJ of some kind. With that in mind, is your tune failsafed for coolant temp? Even well-built EJs will sometimes lose a coolant jacket seal, especially on the open deck engines, and aluminum is not forgiving of any amount of overheating.
All in all, I’ve generally heard good things about AWDTuning and I know the tunes they put together are top notch. I’m just wary since you’ve said they built the motor and it’s leaking oil. That suggests the mechanical workmanship was subpar, and short of detonation, nothing kills an engine faster than an oiling issue.
