Hey was in today to use the woodshop and noticed the jointer was down. My understanding is it’ been down for about a week now? Was wondering what was going on with it (noticed some belts hanging from the adjustment wheel) and when it might be back up and running.
IMO, the most likely cause of the cap and motor failures is overloading due to inadequate dust collection (DC). The new DC system should fix that.
Also, the Powermatic installed motor overload protector can’t be set low enough to properly protect the genuine Powermatic motor and run capacitor. IIRC, the lowest setting on the protector is 15 Amps and the motor’s FLA is around 12 or 13 Amps. I set it as low as it could go when the last motor failed. @Tapper, you might want to ask about that next time you’re on the phone with Powermatic.
