Induction Forge testing
May I please test my new induction forge at the Dallas Makerspace? I just need to test that it turns on correctly, but I don’t need to melt anything with it. It uses 208V, so I would need an outlet that can supply that, and I need water from a hose or bucket to fill the cooling system.
The model can be seen here: U.S. Solid 15 KW 30-80 KHz High Frequency Induction Heater Furnace, Single Phase 220 V, 16:1 Turns Ratio - Amazon.com
Actually, you should probably ask @Team_Blacksmithing about this. They’ll have the proper outlet, as they too have an induction forge.
Seems this same verbiage in a later post has gotten more traction. Go there instead.
