So, I got up at 6AM (Sat. Dec 21) to be at the space at 9:30AM (actually I got there around 8:45AM, but DART time differs) and started running temperature profiles until noon. I finally found one I could live with. Here are the profiles I tried using on the test print.
KISS = KISSlicer for short. The following numbers are in C.
Main Tool temperature (the tool is the extruder), 1st Layer,Warmup, bed temperature
Tool Main temperature is the main temperature used for the majority of the print.
1st Layer - since this is the part that sticks to the bed, you want it a bit hotter than the rest of the print. after the 1st layer the tool temp drops to the main tool temperature.
Warmup = help the tool stabilizes faster. most temperature control systems over shoot a bit before stabilizing the tool. KISS assumes 10 degrees, but 5 degrees is a better number(determined by watching several temp profiles during warmup).
Bed = Self Explanatory.
KISS Defaults are 250,260.180,110
print bottom smooth, over melted (om for short).
2nd attempt 220,240,180,100
3. 220,240,180,100 om
4.210,210,180,110 om
5. 200,200,180,110 om
6.190,190,170, 100 Borderline test was legible on bottom
7. 180,180,165,180,100 Temp too low, plastic failed to extrude.
8. 210,190,180,100
9. 210,190,190,110
10. 210,230,200,110 * Final profile, Good enough is enemy of the best.
Personal conclusions: Hatchbox ABS is a good brand, but this plastic melts at a substantially lower temperature than average. I’ll use #10 profile until I have to buy a new roll. The thing of it is, finding the bracket where the plastic does and does not melt is key. I t will save me time next time I have to go through this. Each print took 9 minutes to print and 5 or so minutes for the teperature to stabilize. I made a minor error on the test print, but I will redraw it and put it here for other people to try.
P.S. I also figured how to remove the plastic from the tool using one hand. With the tool still hot press (dang memory) the opposite of extrude 3 times on Octoprint. The plastic will the pull out with out having to press down on the yellow release handle.
I used to design and build precision hotplates for my old job at Alcatel as a machine maintenance tech.
All in all a good day at DMS for me.
