We decided this afternoon to pull the aluminum sacrificial plate on the HAAS this afternoon.
Lets just say it was bad. As a result the plate is off until we can get the plate, table, Tee nuts & spacers cleaned.
In addition I added some Whamex XT to the coolant to get the nastiness under control. The filter is also damn near clogged but we have some on the way.
No difference than that of the past. The skimmer was running previously 24/7 as well, you just couldn’t see it. That’s as far as the Skimmer goes. We want to get whatever “Crap Growth” under control.
Edit, This Whamex XT can be in the loop during machining operations.
yes very normal. If only you’ve seen what I’ve seen. we’re good.
btw - that was fast. I removed and cleaned under the slab several months back. smelled good I’m sure.
I think @TBJK’s original post was that the sacrificial plate would be reinstalled after the plate and all fixtures were cleaned. Even with the short list of authorized users, we don’t need makers to be makers with that steel table.
Not just crashing - for machining that intentionally cuts all the way through without crashing. Some parts can’t be held suspended off of the bed.
Also a sacrificial “mill tooling plate” like this typically has a bunch of threaded holes to make “clamping” parts on easier than just relying on the slots in the bed.
My input to the discussion: I do not recall a factory that did not have sacrificial plates. The plate that makes up the bed is generally equal to a tool grade surface plate for flatness then the ways are machined into them.
We have sacrificials on vises, even the Sherlines. Why would we not protect the CNC bed? Want help with the decision: contact Haas and get a cost for a replacement. But just a Steel replacement fixture sub-plate (not the actual bed) is about $2,000 vs $500 for a new sacrificial. Assuming the existing one can’t be skimmed again.
How about a compromise. If you want it on for your work, put it on. Otherwise leave it off.
If you insist on it being a permanent fixture YOU do it properly. Install thread inserts, counterbore the face install bolts with seals to keep the holes clean. And remove the plate monthly for cleaning and inspection. Then replace it all.
For reference, this is what I’m used to seeing for a fixture plate
I haven’t noticed any in the job shops I’ve been in, but I can see the utility (and protection) it brings in our case. This style seems much more useful than what’s on there now.
My vote is we keep the sacrificial fixture. I agree with previous mentions of implementing numerous tapped holes for clamping of fixtures. As mentioned, we could put the threaded inserts into the aluminum and install threaded bolts or 3D printed pieces to block off the holes to mitigate the flow under the slab. Here is another NYCCNC video of a DIY fixture plate we could take notes from.
