Expansion Update – 09/25/2019
The Expansion Group had its regularly scheduled weekly meeting last night. Here are the updates.
Completed Contracts:
- The Fire/Smoke Alarm system has been completely upgraded. Both the 102 and 104 sides of the building are now under one system.
- The Emergency Exit by the Electronics Lab now has an electronic latch for Fire Department use only. This allows immediate access to the Fire Sprinkler System should that need arise. Your access badge will not work on this door.
- Almost complete. New stalls have been installed in the Men’s Restroom near the water fountain to replace the old plywood stalls. Per City Code, plywood walls cannot be used in an industrial building. Still waiting on some hardware to complete the job. This was purchased by the Expansion Group and a DMS volunteer installed it. Great job!
Pending Contracts:
- Bids have gone out for Cement work to repair the front entrance by the door. The sidewalk has settled and prevents wheelchair access for ADA compliance. Received one bid, waiting on others.
- Bids have gone out for Electrical work to add electrical outlets in the Flex Area. Many of these outlets will be hanging from the ceiling; some will be mounted on the walls. To reduce cost we are using the existing circuit breaker boxes in the area.
- Bids have gone out for Plumbing work to replace the hot water heater and to add water service in the Science and Warehouse areas.
Work in Progress:
- Definition of the Electrical work in the Warehouse is in process. You will notice a lot of blue tape on the walls indicating where all the new electrical outlets will be going. This is a work in progress.
- Definition of the Mechanical work is in process. This includes new walls for Digital Media, Blacksmith, Water Heater, and the Electrical Rooms. We will be moving several doors around, plus a new aisle through the old Creative Arts room will be built. This is a work in progress.
- Definition of the Ventilation Systems for Fired Arts, Jewelry, Glassmaking, and Blacksmith are in process.
Volunteer Opportunities:
- All items located in the Warehouse must be placed on wood pallets. Also, every pallet must be identified with a white tag indicating the Committee that owns it AND a Person’s Name. This is to help up move equipment as the various contractors start their work. No personal equipment is allowed. Unmarked items will be removed after October 1st. A kiosk with the white labels is standing in the Warehouse area for you to use.
- All of the empty electrical boxes that are hanging from the ceiling in the Flex Area must have a steel wire connected to the roof trusses. We have the tool that does not require tall ladders or the use of the man-lift. This must be done within the next 2 weeks prior to the electrician being on site.
- The sink and cabinet in the Wet Classroom must be demolished and/or removed before plumbing work can be done. This will make space for the new hot water heater. This must be done within the next 2 weeks prior to the plumber being on site.
- We have received the little metal cages that fit around the Fire Sprinkler heads, they need to be installed in the 102 side of the building. These metal cages are already installed in the 104 side. This will prevent accidentally hitting a sprinkler head with ladders, pieces of wood, etc.
- Some electrical boxes in the Glassmaking and Science areas will be removed from the walls. Mounting holes will have to be filled in and re-painted as needed.
- All of the sprinkler heads need to be cleaned through the building. Use a low pressure can of air, like you use to clean a computer keyboard. Do not use high pressured air unless you want a bath and a huge cleanup job. This was flagged during the last visit by the Fire Marshall.
- The new Machine Shop will have cable trays installed 10 feet overhead for their electrical needs. There will be an installation party in the near future to install everything. This is required prior to the electrical contractor working in this area. Check with the Machine Shop for the schedule.
- Emergency exit signs are located throughout the facility. Per Code, each sign must have a single arrow directing people to the closest exit. Some signs have 2 arrows, others none. Need someone to correct these signs. This was flagged during the last visit by the Fire Marshall.
Final Notes:
Expansion is a work in progress. It may seem like nothing is getting done, but there is a lot going on behind the scenes. Defining the requirements from 2,000+ members, getting those ideas down on Engineering drawings, getting approvals from the City of Carrollton, getting the required building permits, getting quotes from multiple contractors, accepting the winning bids, . . . and all this has to happen before the first “light bulb” gets changed. It all takes time. Your patience would be greatly appreciated.
