Post a picture and description of anything you are working on this month at the 'Space!
It can be anything from a small craft project to a large CNC router project to building a table to 3D printing to a science experiment and so much more. There are lots of people doing cool things at DMS all the time, but most of us don’t get to see it. Post it here and share the interesting things you are doing at Dallas Makerspace this month!
Posting here helps not only promote Dallas Makerspace, but could inspire others to make something. It will also help PR post a monthly look at what can be done here on a blog post or other social media (with attribution to each maker of course).
NOTE: Please try to include the following on each post, to help make for richer social media content!
Class Review - Alcohol Ink Workshop 2/1/2020. Excellent class presented by Shay @BarkingChicken. She said this was only her second Alcohol Inks class. Well you could not tell, she was very well prepared and had everything ready at the start of class. No small task since she had 15 people registered. BTW, at least half were non-members and many took the tour afterward.
I’m glad you had fun! I really enjoy teaching this class, so I’m going to keep putting it up on the calendar about once a month until people get sick of it and stop signing up.
Finally getting around to uploading pictures from the Alcohol Inks class (2/1/2020). DMS has my permission to use these for social media if that is desired.
hello. It’s been a while since I’ve done any work on the HAAS. This is an embossing stamp in solid brass. The test subject was a biohazard sign. The back has been cut to accept both handles from the evil empire. The extra weight/bulk of the brass should make for a good impression. And becuase it is brass it can be heated with a torch to use as a branding iron.
The point of this exercise was to zero in on the speeds/feeds that will work best so I can make them faster (see the softjaws for making 3 at a time). Spacing is difficult at this scale. I’m hoping to get good enough to do some medallion work. Raised lettering is especially difficult. Most of this was done with a 1/16" end mill. I tried a 1mm but sadly it did not survive.
The toolpathing was created in Aspire but since this is all 2D work could easily have been done in VCarve. The vectric products are damn inefficient. The code for the biohazard was way to large for the HAAS so I had to stream it.
Looks great! I made a DIY Wash Station from a Magnetic Stirrer but haven’t yet made a UV Cure Station. How is yours working out? What UV lamp did you go with? Looks to be one from Amazon?
