Looking over the documentation, I wanted to check with someone who might have cut EVA foam on Thunder and see if the settings listed are accurate.
All that is listed is “foam” which is a pretty broad category. It lists speed at 11 and max power at 60. Has anyone used these settings or had better results with a different set up?
Just a quick follow up. I did a successful cut of EVA floor mats (1/2 inch thick) with a laser power of 30 and speed of 1500. Any power less than that and it will not cut through, which means, theoretically, you could score this foam at that thickness. I will be trying to score at a later date and will post results.
Scoring for bending works quite well. If you do several score lines parallel to each other you can pull out the thin fins that get left over and get larger more round bends.
