I wanted to triple check if it is ok to cut EVA foam with the laser, Based on the banned list it seemed like vinyl was banned due to chlorine gas, and based on my understanding the EVA foam has vinyl but it is not chlorinated.
“In summary, with the exception of paints, glues and certain films, “vinyl” as a product
description almost always means made of PVC. The term vinyl in ethylene vinyl acetate
(EVA), polyethylene vinyl acetate (PEVA), polyvinyl acetate (PVA), and polyvinyl butyral
(PVB), however, does not refer to PVC and does not raise the same concerns associated
with chlorinated molecules like PVC.”
I am planning to come in today just to practice on some different thicknesses of EVA, I looked at the log after the class and did not see any notes on EVA.
Anyone know what ballpark I should start for foam like this?
The flex tube was covered in Styrofoam blocks behind the laser. I would
also suggest the whole exhaust be checked for leaks (it could be leaking
above the ceiling tiles).
Aside from the test pattern I only ran two jobs at about 12-15 minutes each so the machine was only ever opened three times. I waited until any smoke/haze was clear and the air looked “clean”.
I don’t imagine the three times opened would be enough to reach the front, but just to double check should I wait longer in the future?
