Hello Dallas Makerspace forum,
Have built 12 volt circuit that uses a motion detector, HC-SR501, to activate a 555 timer in monostable mode to turn on lights. The idea is to set the unit in a closet overhead so that when the closet is entered the lights stay on for a minute.
I bread boarded the schematic and tested it and it worked as expected.
A PCB was designed and manufactured.
The PCB was tested successfully using six 5mm thru hole
LEDs as a load for several days.
This a graphic of the 3 layer PCB
A fixture was 3D printed and four automobile back up lights
were substituted for the six 5mm LEDs, OXILAM Backup Reverse Lights 7440 7443 LED Bulbs, 6.2 watts each. (2.06 amps)
The Oxilam LEDs were substituted and tested for about a week and then it smoked
and stopped working.
Figuring some anomaly, weak component or construction mistake, the PCB was
rebuilt and replaced. This time it blew up immediately.
So it was conjectured that the load transistor, Q2 (AUIRF540Z) was overloaded. But I checked the specs and that transistor is (if I read the datasheet correctly.) is good to 36 amps.
So cant figure out why it runs for weeks using the six LED load (20mA each, 120 mA total) but when the system is hooked up to the larger load it blows up.
Have tried simulating with LTSpice but not able to input the schematic.
Any help figuring this out would be most appreciated. In fact, reimbursement is available on a flat fee or hourly basis for competent adult supervision.
Thanks.
Allen Pitts, Dallas MakerSpace since 2018
469 713 4147
[email protected]
