How well do printed threads come out? Assuming they are not tiny …
Machine shop needs two cap nuts to cover the spindles of the Sherline lathes when not in use. The nuts would need about a half inch of 3/4-16 thread on the inside of the caps.
You might want to add a short lamp-pull like chain on them to the lathe to keep them from walking off, but not long enough to get caught up in the works.
You may NOT reimburse me. Even if I pay “retail” at 8 g of material that’s 80 ¢. I will have to print many many more of these before you and I are no longer square!
I live about 15 minutes away so getting here is no sweat. Just let me know when you’ll be around.
I’m up to Nut 4. I will try to get it printed Monday or Tuesday.
Nut 4…
Has the same lead-in as Nut 3. That was a huge improvement.
Has a slightly larger diameter which should make it great for hand-tightening / tool-free operation.
Is round instead of hexagonal. @jphelps preferred hexagonal so it could be removed by tool in case it was over-tightened. Given the cost (dirt cheap; just print another) and the fact that hexagonal was a little uncomfortable hand-tightening I went with round (pliers / plumber’s pliers / pipe wrench would be used to remove it if it was over-tightened).
Has a “hood” that hangs over the left / motor side of the spindle. The idea is to protect the spindle and bearing from dust / liquid / whatever.
Has a taper leading into the hood. This should provide some locking so the nut will not need to be very tight and will likely seal the spindle inside the nut helping to keep out debris.
Is slightly deeper. As far as I know we do not have a 3/4 x 16 bottom tap. The extra space allows ~0.5 inches to be tapped with what we have.
Is slightly longer. This gives a bit more to grip (about 1.25 finger widths / full thumb width) which should make hand-tightening easier. I had thought to go with 2 finger widths but that makes it awkwardly long.
Is slightly larger. This should make it more difficult to lose.
Is nearly hollow. The idea is to make it function like a motorcycle helmet. If something heavy / sharp is dropped the nut should crush absorbing most / all of the force helping to protect the spindle.
