The PLA printer is not working, for some reason at the start of every print it is jerky up. This prevents it from printing on the bed. I didn’t want to mess with it but if anyone who is trained in maintenance of the machine wants to give it a once over. There is some rainbow PLA free to use next to the bamboo machine.
Thank you for posting the problem I am adding a tag to @Team_3D_Fab so the proper persons are notified, Also these topics should be posted in “Issues & Requests”, but you will need to get a Green Dot to access that catagory. Follow this link to request the Green Dot.
Thank you for directing unflared members in the right direction. Please consider instead the same instructions at this link which I think are less confusing given the lack of struck text, etc…
did you calibrate the bed?
@jast & @hforsberg
Thank you so much for the information! I have applied to the green dot and will make sure to post in the correct area in the future.
@engpin
I did calibrate the bed, and I tried a couple of different files with the same issue each time. I didn’t want to mess with it too much though after that.
Ok I’ll look at it later tonight
