@apipe would you please call them, I don’t think Ross is a trainer or part of the support team for the router table. So I’m not sure he knows how to escalate this above the post he made on talk.
What’s the status on this? Was Multicam called?
This is the one machine that i joined DMS for and since the the increase of interest now here come the issues. The other day I was there, i noticed somebody damn near cut clean through the sacrificial board.
I just hope this doesn’t end up getting so screwed up that it ends up on the unusable list due to folks ignorance and negligence.
The nut has been replaced and the machine is fully operational (it was around 1am today).
edited for clarity
What about the z-axis, is it still slipping?
Was it ever slipping?
it did slip at one point and @Chris_Wischkowsky did a minor tweak. It is 100% at this point and we cleaned the collets, some bits and nut last night as well. There is still a pocket in the spoil board but its kinda in the center of the board and hasn’t affected any projects so far, but if you feel it needs to be resurfaced, feel free to do so.
A few weeks ago i was doing a job and Tom mentioned the z-axis was slipping for some odd reason. A few of my pieces also didnt cut all the way through and it was at least 1/8 to 1/4 inch left in the material to the sacrificial board.
So i was assuming this is the same issue @apipe was referring too.
Yep this has been fixed.
We need a small edit to the instructions. The instructions essentially say:
- Set machine home
- Load a bit
- Run spindle warmup
In reality, this encourages loading the bit at the machine home position, which is a really bad spot to try and load a tool (slip out of collet, dinged bit).
We need to update it a bit to go something like:
- Set machine home
- Cancel spindle warmup prompt
- Jog over table (better place for bit loading)
- Load bit
- Run spindle warmup from pendant (it’s the button that says “TEST” on it)
Does that make sense?
Yes sir, got it, i will make the changes.
It’s in the important notes, but needs to be said during startup as well.
• Change the bits over your job to ensure they do not hit the floor
In the instructions can we add some language regarding how to get it out of the “Machine home not set” dialog (or something like that) upon start up. Sometimes it’ll auto find machine home at boot. It takes a couple of button presses but finding that has delayed my projects a couple of times. You may cover this now in the Router classes. I was the a part of the first CNC router trainee cohort/class.
Thanks for the update on the “z-slip” issue.
Lost me on this one, wouldn’t cancel work. I’ve never seen it auto-find home at bootup before, I was under the impression you had to Shift - Go Home to find the hard home at boot-up?
That’s Correct. I didn’t have the “Shift-Go” to find hard home in my notes from the first class and had to figure it out by finding the manual online. IMO it should be apart of the startup procedures before finding your ‘soft home(s)’
AFAIK, this has been on every cheat sheet we’ve ever had.
Also, I’m not sure if you can do anything without finding machine home first.
Oh we got that covered, go look at the new instructions on the Google site, this is what will be posted by the machine.
I need to adjust per @Kentamanos request, but it’s pretty crayon now.
Yeah that’s what i thought, which is why his request confused me, never heard of Auto-home at boot.
Looks good, thanks. I have been tap dancing around this recently a bit and I never remember until I am at the machine :).
