Continuing the discussion from DMS Needs your help :
See my comments below quote:
Hello Makers,
We need your help to tackle some data gathering. This data will be used to help us get our updated Certificate of Occupancy, insurance purposes and help with our tax effort.
We need to find out all equipment in committee areas.
- Does it cost over $500 to replace?
○ If yes please take a picture of it.
- Power to it?
○ Anything other than 110v please list voltage and amps
- Material or chemicals used?
○ Serviced by members or contracted out. (ie: Parts Washer)
- Heat over 150 degrees ( Kilns, Welders, etc.)
- Ventilation to outside? (laser)
- Filtration? (woodshop dust collection)
Please use this google doc form to fill out info.
http://goo.gl/forms/z8s5puVvdn
Results : https://docs.google.com/spreadsheets/d/1Ggu11v3FmBRekqwp_hRowEaE2CIHw9ErZDTvm5Zklss/edit?usp=sharing
Any Items that are free standing (ie: HAAS Mill, Table Saws, etc. ) Should be listed on the map below. Please update it how every you can. Print it off and draw on it. I will then try to digitize it. If you can digitize it into a DXF or SVG that would be ideal.
CA Folks - please add anything so I can get info to Alex.
>110V I don’t know of anything we use in CA.
Value> $500 (assume this is replacement value, don’t know current used value)
Computers associated with printers and Touch Graphic Monitor
Vinyl Cutter, also free standing, serviced by members
Photo-quality -24" printer, also free standing, serviced by member
Wide Format 36" Plotter/Printer, also free standing, serviced by member
CNC Embroidery Machine
Over 150F: Toaster Oven, Steam Iron, Glue Guns
Chemicals
@Val_Curry : Need list of the Chemicals you use for mold making
@AlexRhodes : Won’t list common paints, glues and adhesives (all consumer type in size) or do you need these
Thanks to everyone in advance for providing info so we can support Alex and DMS!
