At this point I’m damn scared to share my 2c, cause I’m the new guy and this is starting to sound like a political issue… but I have some experience with wood shops. I have absolutely no dog in this fight. Joined up because I liked the facilities at dms.
I ran an architectural millwork and casework facility out of college. Largest south of San Antone. It was an AWI premium grade facility.
I’ll say I don’t think that your caps are tripping because of 90 degree ambient heat. Your A/C does it every summer. If that is a concern, I would ask someone with more electrical experience than me to comment on the wisdom of substituting a larger capacitor. Either way, these are industrial motors. They should be rated for continuous duty well above the sub-100 ambient temps involved.
Our shop was in Brownsville Tx (100+ regularly), un-airconditioned, in a high humidity environment. We never blew caps. We ran both one and three phase equipment, using some of the same manufacturers you use. (Y’all have some great pieces.) I had a two-table 3 axis Biesse, two CNC edge banders, a CNC panel saw, and a host of other pieces on the casework side of the house. The other half of the warehouse was pure millwork “traditional” equipment. It all ran flawlessly in the 100+ dog days of summer.
I do believe that the dust collector in your shop is likely undersized. It was the first thing I noticed when I toured the place. If you’ve got more than two machines on a 6" line, you’re probably stressing it. Especially since it basically a trash collector machine. Our Biesse required an 8-10" line at the machine head. We ran an 24" line from it to the dust collector. Everything else ran into it.
Y’all don’t need that set up we had, but it’s worth mentioning because the equipment (wood, HVAC, etc) is only as strong as the weakest link.
I mention this because it’s obvious that dust is a systematic HVAC problem. Pre filters (plural), as previously mentioned, should be a key component in your system, as they are the first line of defense. I hope they’re in the return duct grill coming out of wood shop. Hang a ladder on the wall and change them often.
Seems like we’ve got a bunch of cowboy engineers here (I include myself in that group). Surely we can put together a series of high flow filters that feed into the HVAC return that can be easily maintained from the shop floor that do not require a million dollars or a million people.
Again, I’m the new guy. I want no part of politics. Outsider’s observations. Y’all be excellent now.
