I am going to side with Nick on this one.
My intent for this class is KISS!
I would like to give a basic spiel regarding the different methods in which threads are formed and the pros/cons and purposes for those methods. This includes screw machines (Swiss machining), rolling, form grinding, single point threading and the use of taps and dies. We can also discuss class fits. Fastener locking methods and ways to prevent fastener corrosion in areas such as engine blocks. The purpose of thread reliefs. While I am very experienced in power tapping on the lathe, I will not demonstrate that subject.
We can experiment with what we have on hand. Then, depending on the outcome, we can spend $$ on tooling as required. I will be glad to demonstrate how to grind and dress a HSS tool.
We need a threading tool profile gage. This is used for both checking cutter geometry and for aligning the tool to the work. OptiiVISOR (the lighted version is nice:D:D) and a piece of white notebook paper. DYCEM is a must. Cutting fluid, clean containers for the cutting fluid and acid brushes!
The old standby method for threading long parts with overhand is to thread between centers using a lathe dog at the headstock. This way the work can be removed for inspection w/o jeopardizing alignment. The entire area to be threaded is to be painted in DYCEM. As the dye disappears, you do a fit-check to the female part.
I have a few parts that I made on the Sherline the other night, and I now need to thread them. Using a die would suffice, so I brought my own 3/8-24 hex style (1 in accross the flats). I was unable to find an appropriate die handle…do we have one?
