Most of your discussion has been about injection molding. Are these dies for that or are they dies as in used for compressing material that embosses, deforms or cuts something? Because you are being very circumspect about the shape and size of what is being made or the material that is being processed, it is hard to give a straight answer, since it “All depends”.
Cold rolled vs Hot rolled:
- Cold worked steels are typically harder and stronger than standard hot rolled steels . Cold rolled steel is essentially hot rolled steel that has been through further processing. Once hot rolled steel has cooled, it is then re- rolled at room temperature to achieve more exact dimensions and better surface qualities.
- Compared to hot - rolled steel , cold - rolled steel has a nearly 20% increase in strength through the use of strain hardening. … Cold - rolling steel allows for the creation of very precise shapes. Since the process is performed at room temperature, the steel will not shrink as it cools, as it does in the hot - rolled process
How thick the platens are will also determine availability of Hot vs Cold rolled … and price.
Also how many cycles are you expecting these dies to last: 100’s, 1,000’s, 10,000’s, 100,000’s? The higher the number, then different more expensive materials become cheaper per part but more expensive upfront.
If not for the injection, then chemical interaction probably isn’t an issue and would take SS out of consideration. When you say “High Tensile Strength” any idea as to KPSI? If so then it is pretty straight forward looking up material properties. If weight isn’t an issue, go thicker with many of the mild steels, if lightness is desired then you’ll need higher tensile strength steels or steels in an annealed condition that can be heat treated to higher hardness.
How much pressure exerted on dies, size of dies? Will the platens have gusseting and support ribs that will help spread the load and prevent flexing? Higher tensile strengths tend to high higher modulus of elasticity and resist flexing but are also generally more susceptible stress fatigue. Design is a trade-off.
If the dies are anything like a punch press or forming die, depending on material being processed you’ll need alloy steels that can be hardened including tool steels - especially for punch dies.
As far as the 1" holes, the issue there is really getting the right drills for the materials. I’ve worked with material, a titanium forging that the area we had to drill was inch thick, about .750 diameter holes. Cobalt center cooled drills used: One hole, One drill. You probably aren’t going to be anywhere near that. Harder material need more expensive drills. If done on Bridgeport, problem is cooling and lubrication: you can use a lubricant but cooling really isn’t possible. If done on Haas flood cooling lubricates and cools extending tool life greatly.
You say bushings are going to be used? What are they made of? If a softer material (e.g. brass, bronze) than the guide bars, then less of an issue as they will wear before the guide bar. Just punch them out and replace as a normal wear items. Guide bars that have a good polished like surface finish will last longer. Can they be lubricated. Unless these are going to be cycled a high number of times as long as the bushing are a softer material, probably any steel will be okay. A thin coating of something like Boelube will prevent rusting and help lubricate.
Find someone you trust that works or has worked with metal, show them what you want to make and you’ll get a more accurate answer. There are a lot of people at DMS with a lot of knowledge willing to share and have no desire to steal the design or go into production. Do an NDA if that worries you. Most people that have worked in industry have had to sign a stack of various NDAs as part of the hiring processes - including assignment of IP rights - so they won’t feel offended.
