Hello all, I’m going to buy some clay today and I just wanted to double check that we use cone 6, right? Just want to be sure, thank you!
Yes, that is correct
Can we use premixed clay of cone 10, even though we only do a cone 6 firing?
Yes… but it won’t be food safe. So you would have to make stuff not for serving or eating off of… it won’t vitrify at 6
Yes and no. We fire to Cone 6, but most of the clay we’re usually using is actually Cone 5 clay. That just means that it can vitrify at Cone 5. Clay has quite a bit of flexibility, temperature-wise.
I mean – if you buy clay at Trinity, and Conor’s there, he just gets you the mid-fire clay. I didn’t realize that the Laguna B-mix I use was Cone 5 until I was buying during the sale, and Conor wasn’t handling the sale. I said “B-mix”, and she said “5 or 10”. I believe that the Trinity white stoneware we get is the same (5 or 10).
@sonepi – so, if you’re making ornaments, you’re good to go. If you want to make cups or bowls or plates, you might make a small test bowl, glaze it, and see if it “seeps”. Plus, I’ve heard that crazing is actually caused by a COE mismatch between the glaze and the clay. I feel that test tiles/bowls are the only way to check that. Nobody ever tells us what the COE is of the clay OR the glaze. Ya’ just gotta test.
Thanks Beth
Thank you!
