Volunteer Opportunity: Replace Drinking Fountain Filter
As we all know, the drinking fountain is now in the red for filter usage.
I’ve bought a new filter from Amazon, should arrive on Tuesday-Wednesday. I’m looking for someone to:
  • Turn off the water line (under the fountain)
  • Unplug the fountain for safety
  • Take the bottom cover off (held on with 4 6-10mm bolts)
  • Figure out if any prep is needed to remove the filter?
  • Replace the filter
  • Water line back on
  • Power back on
  • Ensure filter light is reset
Tracking: https://tools.usps.com/go/TrackConfirmAction?tLabels=9361289670090351266883
**NOTE**: This category is **NOT** for discussion threads. Any "discussion" will be split out by one of the TALK Moderators to create a separate "discussion thread".
Where are buckets typically kept? (To put under the old water filled filter.)
Should be buckets in automotive and the janitors closet, use what you need :slight_smile:
if this helps…
For what this is worth, it states no need to turn off the water (might want to do it anyway…)
status light reset procedure starts here
Someone finished it!
