Got a troubleshooting help request. (Troubleshooting devices without schematics stinks, doesn’t it?)
The picture below shows two chokes. The upper one goes to the pretty little tube up top, and can be ignored.
The lower one takes in 18VDC from the wee plug there, and runs to two terminals, as is fairly visible. On the other side of said terminals is a socket for a UVC bulb – much like that nicely toasted one pictured below the component… I’m sure you guys see where I’m going with this.
Choke’s got a short in it (significant enough to generate enough ozone to smell significantly, nearly immediately) so I’m loath to do a lot of powered testing and just make the problem worse. It’d be nice to just swap this sucker out with another 18VDC UVC ballast.
But then there’s that extra wire… I’ve never seen a ballast with one extra wire, and have no idea where it’s supposed to run to. Which is the mystery I’m trying to solve. Yes, it came with that sheath – but there’s nothing that would get particularly hot in this device anywhere where I could imagine that wire running. (It’s an air purifier – small motor, couple of vanes, ozone generator because it’s old and ozone generators hadn’t been tied to all that harmful stuff yet, the UVC antibacterial bulb, some control electronics. Pretty simple beast.) Hesitant to apply voltage as I stated before, plus if the choke’s shot I can’t really ensure any voltage at the wire would be correctly representative anyway. Dead-circuit continuity is open from the wire to basically everything I can put a probe on – I imagine those blue blobs in the white solid epoxy-ish stuff that look suspiciously like mica capacitors probably have a lot to do with that. Though of course, whatever that white goop is in that thing makes it impossible to probe – or identify – much of the circuit.
Okay, that’s my brain dump of the little I know. Probably tl;dr – thanks, if you’ve made it this far. Short of throwing this thing away (exceedingly tempting, except that apparently it inexplicably goes for around $200 new, I’m told? sigh), and seeing as the manufacturer doesn’t seem super keen on releasing schematics to me, any suggestions on how I should proceed?
