What are you intending to capture? What do you expect to see in the frames? At that frame rate you’re not going to get much in terms of resolution (single digit or double digit pixel vertical resolution). Expect to spend a few thousand dollars per day for rentals. There are tons of rental companies including directly from manufacturers that can mail the equipment anywhere in the world. Quality of cameras, lenses, software, recording duration, light sensitivity, dynamic range, resolution, and other features vary wildly so the details of what you’re trying to do are critical. You might need other equipment depending on what you’re trying to do (lights, stands, tripods, meters, etc.).
