I’m making a telescoping assembly with (multiple sets of) three pieces of brass tubing; 2mm OD, 3mm, and 4mm. I was expecting a friction fit but the assembly is more slip than fit. Without benefit of using the pin gauges, I’m guessing the smaller tubes are a few thousandths less diameter than they need to be.
Any suggestions? I’m open to changing either the smaller or larger tube somehow. I don’t need the entire length changed if one end is a friction fit.
Here’s what I have tried - all of these were on the inner piece of tubing to try to increase its OD at one end:
- A little bead of solder (and then turning it down to size). I couldn’t control the sizing well enough (because the solder didn’t go all the way around the tube).
- Knurling near one edge. Since I’m using a tiny jeweler’s knurl it didn’t raise the OD enough to make a difference.
- Bending the end ever so slightly so it would rub on the other tube. I was able to get a friction fit this way but very slightly changed the alignment of the tubes.
I’ve considered flaring one end of the inner tubing but don’t have a suitable flaring tool.
All suggestions are welcomed!
