@Comter discovered a problem tonight using Thunder 63. The bed had shifted and was caught under the frame. The bed was also no longer aligned left to right, being lower on the right.
We pulled the bed out. It’s pretty rough. I put a flat board on it and walked it, reducing a few little high spots. A replacement should be ordered.
We then put it back and leveled the bed. It should be OK for now.
Problem: There is very little clearance for the honeycomb bed. I don’t remember it being so tight a fit. The binding that happened, with the bed shifting under the frame, is likely to happen again. The bed is not pinned in place, as it is with the 2 Thunder 35s.
Front Left
Back Left
CameraZOOM-20180627232517655|375x500
Front Right
Back Right
