I have been doing some test cuts. Part of the way through, I realized that when I hit “start” on the laser, the power and speed flash and change back to some values set in Lightburn.
This meant I had to go back through and correct my test notes; and it also seems problematic from a testing perspective. What is the best way to ensure that the laser can override these file settings?
Video upload is not authorized but I recorded it. Edges were nearly perfect: probably a little more power or less speed would have resulted in perfect edges. No flames.
Edges were clean. No flames. The edges resist fraying but it doesn’t form the melted, annealed edges that nylon webbings or Cordura form. This is Tweave in a lighter weight than 520E; I believe it is marketed as 544P.
