Sunday morning : met up with a friend for a lesson on how to replace thr parts that needed replacing from a previous vehicle maintenance inspection at the Makerspace.
Front & rear brake pds and rotors.
Rear struts and mounts. KYB struts made in Japan. Not ‘quick strut garbage’. FYI-Miata hardtop convertibles make gaining access to the top mounting nuts an exercise in patience.
Rear anti roll / sway bar links.
Front struts and mounts, valve cover gasket are next week. Mini cooper door lock actuator cable is very unpleasant work.
