May not have the same views as stan but looks like we’ll also need to plan for a major upgrade too. 2.1 is out and we’re drastically behind.
Just something else to have on our radar. In the mean time looks like sidekiq can be pulled out of the stack as its own container and deployed outside the main system. If we make talk into a docker swarm then we can dedicate a few temporary vms just for the message queue and take them out of the swarm when its done processing.
Deployment script
Borrowing from my devops talk repository:
#!/bin/bash
# build.sh - create a docker swarmmode cluster then deploy a service stack
# Copyright (c)2017 Dwight Spencer <[email protected]>, All Rights Reserved.
ENVIRONMENT=${ENVIRONMENT:-"stage"}
MAXWORKERS=${MAXWORKERS:-"5"}
MAXMASTERS=${MAXMASTERS:-"3"}
SERVICES=${SERVICES:-"services.yml"}
alias swarm="docker swarm"
alias machine="docker-machine"
alias compose="docker stack deploy --docker-compose"
dmcreate() {
machine create --engine-storage-driver overlay 2 -d generic $@
connect() {
local max=$1
local name=$2
local command=$3
local token=$4
local master=${5:-""}
for x in `seq 1 ${max}`; do
eval $(machine env ${ENVIRONMENT}.${name}-${x})
RHOST=$(machine ip active)
swarm ${command} --advertise-addr $RHOST --listen-addr $RHOST --token ${token} ${master}
done
#vpc=$(aws ec2 create-vpc --cidr-block 10.0.0.0/16 | jq -r ".[].VpcId")
#aws ec2 create-subnet --vpc-id $vpc --cidr-block 10.0.0.0/24
#aws ec2 create-subnet --vpc-id $vpc --cidr-block 10.0.1.0/24
#igateway=$(aws ec2 create-internet-gateway --vpc-id $vpc | jq -r ".[].InternetGatewayId")
#ngateway=$(aws ec2 create-nat-gateway --vpc-id $vpc | jq -r ".[].NatGatewayId")
#iroute=$(aws ec2 create-route-table --vpc-id $vpc | jq -r ".[].RouteTableId")
#aws ec2 create-route --route-table-id $iroute --destination-ipv4-cidr-block 0.0.0.0/0 --gateway-id $igateway
#aws ec2 security group ...
for x in `seq 1 ${MAXMASTERS}`; do dmcreate ${ENVIRONMENT}.master-$x; done
for x in `seq 1 ${MAXWORKERS}`; do dmcreate ${ENVIRONMENT}.worker-$x; done
eval $(docker-machine env ${ENVINONMENT}.master-1)
export master_ip=$(docker-machine ip active)
swarm join --advertise-addr ${master_ip} --listen-addr ${master_ip}
export manager_token=$(swarm join-token manager -q)
export worker_token=$(swarm join-token worker -q)
connect ${MAXMASTER} "master" "init" ${master_token} ""
connect ${MAXWORKER} "worker" "join" ${worker_token} "${master_ip}"
compose services.yml ${ENVIRONMENT}
