As I am reassembling my under-hood situation in the Mazda, my multi layer steel head gasket replacement has me worried. And I think I have just cause. Let me explain.
I used Felpro PermaTorqueMLS gasket which has steel and sealants in its construction. My heads are aluminum and I think my block is aluminum alloy as well but may be iron. I really am that dumb when it comes to metal.
But where I am less dumb is measurement and mathematics. And this is where my question comes from. You see, felpro specifies that max 30 Ra is required for most MLS applications. But that their PermaTorqueMLS line can handle up to 60. The problem is that they did not specify units. In fact, no one in automotive industry is taking much care to properly specify their units when discussing this Ra requirements for head gaskets of MLS variety. A few have mentioned microrinches (otherwise known as mils), and I am under the impression that this is the requirement felpro is suggesting.
But there is a huge problem with .03 inch or 30 mil Ra requirement. It is not smooth at all. This much average roughness is quite rough, actually. Andj to understand why, lets think about what .03 inches of average roughness means.
One way to measure surface roughness is to use a profilometer. This device uses a sharp diamond tip, and slowly drags itself along the surface while measuring and recording the height the diamond tip reads. To compute Ra, the tool must take all its sampled measurements and average them. Then it would use the average to determine the deviation of each sampled measurement (taken as it drug across the surface) from that average. Since the deviations from this average surface height are both positive and negaive, the tool must then take absolute value. From this, the tool now has a set of positive deviations from the average for every measurement point (or sample) taken. To get the overall average, the tool must then average all of these deviations together.
So a .03 mil roughness surface would actually have .06 roughness since the absolute values had to be taken. And depending on shape of these deviations, likely peak to peak is double that, so now we have .12 inches peak to peak roughness. Most handheld metal files I have used are much smoother than that. The .12 inch peak to peak surface would for sure never be described as āmirror-likeā which is what I see the gurus calling a .03 Ra surface.
Where did I go wrong?
Secondly, I donāt think Ra can be used to completely characterize the surface requirement needed to properly seal an MLS (multilayer steel) head gasket. The situation is more complex than that. You see, a single surface discontinuity of .06 inches (like a step function) would result in .03 Ra if it were perfectly smooth otherwise. And I doubt a surface like this would do a great job of holding the coolant, or oil, or pressurized hot gasses in the cylinders. There are a lot of other surface imperfection shapes that would be massively problematic, but could still pass the .03 Ra requirement. So an additional surface parameter must be specified and required. Maybe even two or more additional surface specs are required. Has anyone seen a gasket maker or OEM equipment manufacturer nail this down properly?
To summarize my questions:
- What is the correct unit the automotive industry intends to specify when discussion Ra, as mils makes no sense at 30 being mirror-like?
- Has anyone seen surface roughness requirement called out in such a way as to appropriately restrict the sorts of surfaces that would work in an MLS or other sort of gasket application?
