First: How accurate do you need, e.g. deviation per inch. This will determine if it nees to be reground if out of specification.
Do you know what class of plate it is?
- Three standard grades of flatness defined by the federal specification:
- *Laboratory grade AA: (40 + diagonal [in inches] of surface plate squared/25) x 0.000001 in.
- Inspection grade A: Laboratory Grade AA x 2
- Tool room grade B: Laboratory Grade AA x 4
Google Metrology Laboratories in North Texas or DFW.
Just a wild SWAG I can’t imagine it being less $100 to inspect it and give you the inspection diagram. The diagram will be like a contour map of the deviation from a flat plane. The advanatge of this let’s say you need Inspection grade A. 3/4 of the plate may be “A” the rest “B”. They will cert the plate to just “B” but if you know where where the “A” boundary is you can mark on the side of the plate the boundary and if that is acceptably big enough for your item then use that rather than regrind it. No idea the cost of a regrind.
I assume there is no visually apparent chips or damage that need repair.
If you get the plate certified I’m assuming you having the height gauge, indicators, etc. also calibrated, if not, there really isn’t much point in doing the plate if you don’t know the accuracy of tools being used.
Is the plate new when you bought it? There should have been a factory cert that came with it. Unless you are doing work that requires certified inspection equipment (which would mean all measurement tools) that cert should be good for now.
