Absolutely agree. If you open it, you should still see the red sharpie
marks I put on them. Those were the leading edges. All but a couple
rotated CCW 1/4 turn. CW was not an option on most or them. Part of the
reason we talked about just starting with a fresh set so it’s known they
are all at the same level of wear.
I’ve had issue with sharpie marks and cleaning the blades. The two times I’ve rotated the blades, I marked the edge with a sharpie. When I cleaned the blades, the sharpie washed away in the solvent cleaner.
Rather then sharpie, your best bet would be to use layout fluid. It can be removed with acetone, or pressure washing, but will stand up better then anything I have used. It is also very thing and shouldn’t effect geometries.
I’ve never been able to control layout fluid well enough to only mark one small part of anything
Layout die comes in 2oz bottles with a sponge applicator tip. Real easy to control fo this kind of thing.
I use a Q-tip with my Dykem. And BTW, I could swear I saw a can of it (blue?) on the table by the Bridgeport.
