I am considering a project that will require sublimating a long aluminum panel that is about twice as wide as our heat press. I can tolerate nominal “seams” in the image but would prefer to not separate the panel if possible.
Can I sublimate one section, move another section into the press, and keep moving across the panel that way? If I do that, certain portions of the image will be heated up twice. Will that affect how the image looks in that area? Should I peel off the paper in that area before I re-press it?
