Unless you’re machining with a needle at 50k RPM it’s not going to do any machining.
Let’s say you load up a 1/2" endmill in the HAAS 3/4 tons of side load.
Assuming the spindle and collets etc are weightless, with our 1.6kg of side load force we’d need to have an endmill diameter of 0.024" to get the same force per rotational speed (chip load).
Maybe we get a dentist’s drill for it? Pneumatics should save on weight and give us closer to the RPMs we’d need.
Edit: crummy napkin math:
(0.75+907.2)/(pi*(0.25)^2) = (1.6)/(pi*(x)^2)
solve for x, x=0.012 as a radius
0.024 as a diameter, so less than a 1/32" and more than 1/64"
