Can we get/make some kind of dedicated sharps disposal box(es) or blade bank things for CA? …for all the exacto and cutting blades as well as bent and broken sewing pins and needles, etc so they aren’t just getting pitched in the trash. I’m not requesting the dedicated bio-hazard type boxes per se due to cost, but just something dedicated and marked for that purpose. Maybe magnet the containers inside a door on the sewing, fiber and leather cabinets specifically or else have a way to mount them by the trash cans so they can be dumped safely for disposal. Just spit-balling ideas… I use a big 3.4 oz Tic Tac container at home with a an old rotary blade case glued to it…whole thing is stuck to my bench rail with a magnet. Before that was an Altoid tin glued shut with slit in the long side, but several rotary blades pretty much filled it up.
There are a couple of them we could 3d print on Thingiverse, just need to make sure the slot will accommodate rotary blades, too. http://www.thingiverse.com/thing:72966
Not really…had some disposable type containers dropped off that I think were for this purpose, but they were pretty big…thought I could use them for CA in general. …but was hoping for something I could magnet to the door of the leather cabinet, so it’s right there when we’re changing blades and them dump them in the big container when it got full. Just needs to be wide enough to take the rotary blades and maybe twice as tall as that and an inch or two deep. But I’m not really that picky about it…I’d be grateful for whatever you have in mind!
