If I were to use a small steel bolt (#0-80) to align my bronze and brass parts during solder, in theory I could just remove the bolt after soldering because the solder shouldn’t stick to the steel? Right?
Details: I need to solder a (small) bronze casting to some thin wall brass tubing. I plan to use brass wire solder (1330 degrees - approximately comparable to “medium” jeweler’s silver solder) and a small torch.
