By any chance, do we have a small torque limiting electric screwdriver at the space, or a small gauge for measuring screw torque?
I need to remove and replace several dozen lids, a few times each, and I’m looking for a way to do it quickly and without striping the plastic. This is the enclosure: https://www.polycase.com/lp-35f
you probably need a low torque screwdriver in inch pounds or fractions of inch pounds - I used to use them for repairing night vision for pilots and infantrymen in the military.
I currently have a HIOS CL-6500 on loan to Vector. Its torque may be too high for your application, but it may not be. I would probably need to see what you’re working on to be sure. If you decide to try it, make sure you turn the torque limit way down on the first attempt.
I also have a Duratool CL-3000, which may be more appropriate for softer plastics. In the event the plastic you’re working with is easily stripped, I also have an Utica TS-30 and TS-100 I could let you use one of. I’m not as keen on loaning them out, but I would be willing to bring them to DMS when I’m going to be there for a while.
