Short-term, I am not building a simulator; my only reason for building this is to use it for a few screen tests followed by a 1-day shoot with 1 person in it. It will tilt about 30 degrees forward and back, and maybe 30 or 40 degrees side-to-side to give the appearance of a P-51 Mustang in flight. Rotation will be done by hand.
Refining the design for the support structure has taken more time than I thought it would. For the past few days, I have been running FEM analysis on the design and iterating on a couple of different approaches for attaching the cockpit to the gimbal, which is where the most significant stress concentrations will be. These simulations are imperfect and completely ignore the quality of the welds, but after a couple of days, I was able to attain a minimum safety factor of 2–3 (with around 99% of the design at 8+) and get 1–2 mm maximum displacement while the cockpit is tilted 30 degrees forward. The structurally important side cross braces were excluded from the simulation as a rough compensation for the unrealistic metal joints.
That said, there are a handful of joints I want to be absolutely sure are done properly, and I know I’m not the person to do them. It would also be nice to leave open the possibility of making this into a simulator at some point in the future. Do you have any recommendations for welding inspectors or engineers?
