Hi,
I use Fusion 360 hobby version, and I have a few simple designs like custom spacers and holders/clips and things. I typically create my design in inches as the unit of measure.
While I was able to get one design to print, I’ve had issues with my most recent.
- Is it just EASIER thinking of the whole process; to have a design in mm??
- like… exporting the STL, importing the STL and slicing it and exporting it to geocode then importing it to print…
- Does anyone know - if in Fusion 360 you can simply convert your model in inches to MM?
- Fusion has an EXPORT screen, and in the export screen it gives you an “option” for the units of measure for the export. If my model is in inches and yet I select MM as the unit of measure for the export - does FUSION 360 do a conversion?
It’s rather frustrating to take the time to design something, and then run into issues trying to slice it and print it.
Thanks In Advance for Suggestions and really Answers Here
