Z Steps; For an unknown length of time the steps per mm on the Z axis of the Shapeoko has been incorrect. The symptom is depth of cut being much less than specified; e.g. specify 15mm and receive actually 9mm of cut dept. I’ve fixed this and added known good settings to the Wiki page
VCarve: If you’re using VCarve to generate gcode for the Shapeoko please use the post-procesor labeled “Shapeoko Fixed MM” - it’s been tweaked so the initial retract is 5mm above Z start. The regular Shapeoko post-processor was using the XH variable for this and sometimes the movement was so large it exceeded the Z-Max on the Shapeoko, causing the spindle motor to hit the top of the carriage
P.S. 2 classes in early June are on the Calendar.
Thanks!
