So i am trying to combine two different activities i have recently learned here at the Space.
I took a great class on making Bisque plates using craft foam.
They use the thin craft foam as a template to first make an interior 1/4 inch center piece that you will later use as a press on the actual clay piece that will be your plate.
Unfortunately for me my scissor and exacto cutting is not near as good as the ladies in my class.
I was thinking i could use the Shapeko to 1) cut out my foam templates and then 2) skip the making interior clay piece by routing out a porcelain piece that would be my center press piece.
Using the Shapeko would allow for extremely accurate and repeatable patterns.
And i just kind of want to use the Shapeko, lol.
Anyway, that is why i was asking the questions.
I do still need to know if i am buying a cutter for foam, would it be better to get an up or down cut bit.
Thank you!
Michael
