Hey, just wanted to let the group know there’s a serger on the baby lock zest table with a note on it that it’s broken, not sure what happened or who the note is from but wanted to pass that on!
Looks like the upper looper arm is rotated a couple of degrees out of the proper position. I’ll see if I can reset it and get it back up.
Edit/update: Got the looper unjammed, but the inner needle stitch keeps throwing itself out of the chain. There’s probably something else in the timing that’s still iff that I can’t diagnose.
I’ll look at it before the meeting on the 9th, please use one of the other servers and put the serger (with the note) on the shelf
You might want to ask for your Green Dot. That should be a category on Talk. I can’t see it because I have my Green Dot (denoting membership). That will give you access to the Issues and Requests category, which is locked to people with membership. Talk is completely separate from the Active Directory, so humans have to look up the membership.
At any rate, thank you for posting on Talk.
