Hello everyone,
I was hoping that someone might be able to help me with an issue that I’m running into trying to run Post-Process to generate an .NC file in HSMWorks. I’m using SolidWorks 2016 +HSMworks. I’ve generated the tool paths, run stock simulations, and everything seems ready to go with my program. I hit “Post Process” button in the CAM ribbon, and then when the window comes up, I adjust the setting to what you see below:
When I press “Post,” I get “Error: Failed to evaluate post configuration.”
It doesn’t seem to matter what I try to send out to Post Process, it fails every time. I’m not a programmer, nor am I very experienced with HSM, however, it would appear that there’s maybe an error in the HAAS-VF2.cps file somewhere around like 319. Has anyone else experienced this? If so, how do I fix it?
