Hello. The discussions for open house have started. I’ve got two of these rotating zippo displays (we can cover up the zippo part). I used to use these at the flea mkt and not just for lighters. It holds 60 items. Because the trays are 3x4", I would put wallets in the slots, jewelry (on a card) and basically anything that will fit. I’d like to offer one to Jewelry since it works well for that. I know space is always an issue but I don’t believe we’ll be doing any real work that day and depending on what demos you might be running it could be up front during the dead times. The one I have in mind is battery powered so power is not an issue. If you need more items to fill it, perhaps one of your neighboring committees will pitch in. If you need more, I have two that are twice the size. Just let me know. It should be fun. cheers!
What size does the card need to be?
It would be nice to have one side with exampled of the
various types of jewelry we do, from casting to fabricated to
the multiple styles of wire wrap,
Along the same lines I have a number of the glass cubes that
are glass that is fastened together with metal connectors
I believe the cube is around 15 x 15 inches, the y can be linked together
get in to
I beleive that they can have a back fastened on it would not be easy to
These might be good for some larger items,
I am willing to loan them to the space for the open ouse
not large. the max would be 3x4 but smaller (like jewelry box inserts) is what we used.
we can always use double faced tape to secure anything from falling.
I make my own earring cards and I have some card stock
I also have some mat board cut offs that could be cut and used
