Thank you very much @fedakkee
What is the purpose of leveling the board twice? Isn’t it parallel to the cnc after milling one side?
There’s a coating on both sides that seals it and the vacuum can’t get through it unless removed.
Please, please use the calibration block to set Max Depth every time you use the machine. It’s easy and won’t allow the bit to travel past it. That includes setting Max Depth for every bit change.
You can adjust max depth using the up arrow + max depth keys on the keypad and using he z up arrows to fill a few thousandths. But if the vacuum is working and the MDF isn’t warped it should cut all the way through the material.
Too late. Someone failed to set Max Depth today. The spoilboard is already torn up. Logs reveal who it is. Maybe people who fail to set Max Depth need to be tested out again. This would be an automatic failure. So sad. Not even 24 hours had passed before someone thoughtlessly tore up my baby.
Maybe a better lesson would be going and getting another spoil board and resurfacing it. That would probably reinforce setting the depth correctly and making a depth mistake again.
Ya, Let them know the cost, its weight, and all the prep involved.
No, they’ll discover and learn that as they go through the process - a believe the current terminology is “A Teachable Moment” or something like that.
So…are we able top pull the footage so we can identify the person and have the teachable moment?
Although - a teachable moment already happened. This person saw what happened. Next they need to be held accountable. Give me access to the BlueIris server and I’ll find the video clip…
I just pulled up the logs so I have name.
That’s a pretty significant oops for a brand new spoilboard
Dang! This is why I bring my own “spoil board”; a scrap I can attach my piece to that the vacuum holds and won’t matter if it gets buggered up.
That’s a great idea. Esp for new players.
So I cleaned things up and added some decorations to the MultiCam spoilboard. What do you think? Did it spruce things up a bit?
They’ll still set their maximum depth, it’ll just be below the surface of the spoil board.
I think the operator should have to put a couple $100 bills under their project. Bet things run shallow.
Some have asked how I designed and made the stencil.
Pretty simple with Fusion 360.
This would make a great class!
Great idea, let them destroy “their” money instead of DMS’s.
